That's nothing specific to NTFS - same for FAT32, ext2, ext3 - you'll need some special software in order to be able to do that.I've used it. I was unimpressed with performance and stability. Disks are best directly attached to a machine, or abstracted away with something like NFS or CIFS.
Also, note that using NTFS over iSCSI doesn't work---you will corrupt the filesystem fairly quickly. You need to share the drive another way if there is more than one machine mounting it.
