IS7... starting up is 50/50
bjork
hey all, i mentioned in passing on a different thread that i've been having issues with my new IS7 during booting... and two other people mentioned they have the same issues. sorry for starting a new thread, but i wonder how many of us have this problem...?
my IS7 is rev. 1.2, and i'm using the newest BIOS (just flashed yesterday in an effort to see if it fixed the problem).
i'm running a P4 2.2c at stock speeds (for now) along with 2x 256MB Corsair XMS 3500 sticks of DDR. (power is being supplied by an "antec true power 550" that worked flawlessly in the previous system i had... an athlon 2500+ on an Asus A7N8X
Deluxe with these same DDR modules)
the problem: sometimes on a cold boot or restart, the box just sits there... it goes thru a POST just fine, and then just sits at a black screen (before the XP logo loading screen), or the XP loading screen loads, but it never "makes" it to the login screen (goes blank, and will just sit there until i reset it). other times it boots up just fine.
all these components work just fine, the only new items are the CPU and Mobo. plus, i did a clean wipe of windows upon installing everything....
like i said, i'm not OCing it, and have loaded the failsafe defaults, but no love.
how many others are having this issue?
any ideas? new mobo battery or somehting lame like that?
:confused:
Bam! Bingo! That's the problem buddy. :)
Setting your memory timings relaxed and turning off GAT should ease up on it and allow it to post. Also, make sure the ram ratio is 3:2.
Since you're running at stock speed, I think it may be your ram sticks causing the problem. Try running different sticks and see if you get more stability. I presume you have your bios settings at default.
jack,
can you help clarify what CH-5 is?
i've poked around on google, but even when i think i've found an explanation, it takes a turn and doesn't say much...
