MemoryInAGarden
- Oct 26, 2003
Still putting together a system with an Antec Sonata, IS7, 2.8C, GEIL PC4000, and WD 120GB. I'm having pure hell with this combo. For those that have the Sonata, how do you attach a hard drive and an optical drive on the same ribbon? Since the hard drives mount sideways with the ribbon and power end of the HD facing the motherboard, it would be nearly impossible to connect the HD as a slave, wouldn't it? The IS7s IDE connectors face horizontally instead of vertically, compounding the problem. This leaves me with two badly bent IDE ribbons. Does anyone have any ideas on how I might be able to adjust the hard drive case so the ribbon end of the HD is facing the back of the case instead of the side? Would rounded IDE cables help or would they be damaged with all the bending? I heard this was a great case, but this has been the nightmare build for me
