IS7 doesn't run 250FSB 1:1 stable
This seems to be really odd...as I know it isn't the chip. The chip has been verified to do 310FSB on water and 300 on air. I can't run 250 1:1 stable at all. It boots into Windows for maybe 5 mins then reboots itself. However, It can get into Windows at 3.6 ghz on 3:2 and is stable at 3.3 ghz on 5:4. Think I could just have a week board that doesn't play well with high memory speeds?
Well my IS7 was okay at 250. Maybe its your memory.
I had some OCZ 3500 ( i forget the exact model EL maybe) that didnt like the 1:1 ratio. Up the VDimm as much as you can (its only 2.8 i believe which kinda sucks) cuz some memory lies to you. I had some ADATA PC4000 that wasnt stable at rated speeds/voltage. Maybe it was the heat or something who knows. Bottom line is I ended up using a lower ratio. That 1:1 wont make THAT huge of a difference anyway.
Its most likely your memory. I have no idea why I made the dumbest decision to go ahead and buy PC3700 Kingston HyperX RAM. I don't even know why they make this shit - it overclocks like shit, infact I don't even overclock at all anymore. I know not all memory is supposted to be run overclocked but coming from their HyperX line of products, I am dissapointed to say the least.
