- Dec 9, 2000
well in another situation
my current motherbord the Intel 975XBX seems to have issues with cutting out the sound to my receiver via SPDIF RCA Cable, while watching a movie mostly DIVX / XVID encoded ones it seems to cut out every once in a while and it will give a weird popping noise, then come back on.
Now here are my options, 1 Sell the mobo and go for the Gigabyte DS3 (which did not have this problem)
2 buy a sound card again. my 2 options are
Audigy 2 ZS OEM for $79,99
or
X-FI Platinum for $199
why theplatinum you ask? well The regular XFI cards only has 4 jacks, 3 for speakers and 1 for Mic/Line In/SPDIF out, I have a mic I need to use and I have SPDIF I would like to use also =/
so the question is
IS the XFI worth the $ over the ZS and what are the benifits?
or
so the question is
