Question to all you experts out there... is water cooling really necessary? Here's what I have going on:
I haven't built a new system from scratch since 1995... when the 486 was king, and the Pentiums were just coming out. Back then, you popped the CPU in the ZIF socket, locked it down, and presto... CPU installed. Since then, I've purchased from HELL (Oops, I meant DELL) almost exclusively... due to my newly formed rather poor opinion of them, and the savings to be had on a custom build, I'm opting for the custom build for my new system. Now, I know a lot has changed since then as far as custom builds and mods go, but generally most things are basically the same, so having done this before (even if over a decade ago) and always upgrading my existing systems, I'm no stranger to the inside of the box.
Having said all that, here's where I'm at. The boss (my wife... aka my sugamama) has granted a generous budget on the new system... not to exceed 4k... with the expectation that it'll last another 4 years or so. I've decided on the Intel Core 2 Extreme Quad QX6700 and two GeForce 8800GTX in SLI. So, I'm all set to go, and I've been doing all the necessary research, and I'm ready to buy and build... almost.
One thing's got me stumped. I know all the blazing speed by the latest artwork by Intel and NVIDIA's got the cost of extreme heat. I get that much. And I read all the time that liquid cooling is "way better", which is great, but still, is it necessary? Especially considering that the gfx cards I'm looking at have built in fans and such, and the CPU comes with it's own stock air cooling, and I can't believe that they'd sell something that wouldn't be enough to cool it sufficiently. (Or would they?) So, is water cooling really necessary, or is the stock cooling just fine? Granted, I'm assuming this has something to do with usage of the system, so I'll tell you about that... I've always pushed my machines pretty hard, I code, I game, I render with Lightwave 3D, and I run my systems almost 24x7. (Usually in a project, don't want to "reset" my environment.) One thing I've never done is overclock. (That might amaze some of you, but I just never felt the need to.)
So, what it boils down to is this... There are four problems I want to avoid:
(1) I absolutely do NOT want to fry any part of my system via overheating. If I have to buy a new CPU because I fried the old one, I doubt I'd have the chance to do so, so I'd be screwed.
(2) If I choose liquid cooling, I absolutely do not want any accidents that might damage the system via short-by-moisture. I do occasionally have to transport my systems, and I wouldn't want to jostle things loose and get everything wet. I also don't want ANY condensation or leaks inside the box at all. Honestly, I'm a bit scared of the idea of pumping liquid inside my soon-to-be-BEASTIE.
(3) If I choose liquid cooling, I do not want to have to refill the d@$% thing periodically, I don't have the discipline for it, to tell you the truth. I'll forget, and I'll wind up frying the system anyway. I'm hoping that on most cooling systems, refilling is not necessary, or that refills are very seldom, and the system warns you when it's time... that wouldn't be TOO bad.
(4) I don't want an overly noisy system. My current system is a classic Pentium 4 (5 years old, doesn't even have HT, sigh) and it has a nice gentle fan hum to it, like all my other PCs before that one. I've grown quite accustomed to it, and honestly, I find a gentle fan hum comforting somehow. On the other hand, my wife's new machine, considerably more recent, has a side fan that changes speeds, and on high speed sounds like a jet engine... it drives me nuts. So, I'm looking for some comfort noise, but not lots of noise.
So, given my situation, is it necessary to use liquid cooling, or is the stock air cooling just fine for my particular use? If liquid cooling is highly recommended, then do I cool the CPU only, like I see so many kits offered on NewEgg, or do you guys really recommend liquid cooling other components as well... and if you recommend the gfx card in particular, how the heck to I apply it without voiding the card's warrantee? It's not like I can take it apart then complain to the manufacturer that it's busted.
What do you all recommend for me? Liquid, stock air, or custom air?
One last question... are there any brands of cooling to look at in particular, and more importantly, certain brands to avoid? Same question for motherboard brands. I have this one shot to put together a kick-A system, I don't want to screw it up.
