Is trayless hotswap better?
zikzak
I'm looking at all these hot swap cages, and am not familiar with the criteria I should be using to differentiate.
  • Is trayless "better"?
  • Is 1x80mm fan going to be significantly quieter than 2x60mm fans?
  • Does anyone have a good suggestion on the best cage?
Trayless typically is faster to swap a drive. otherwise not a big deal one way or another (IMO)
I onlt saw two identical (other then the color) iStar units. I've always seen this supermicro hot swap cadge recommended:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121405
The only thing with these units is you'll likely have to buy a replacement fan that spins alot slower. since the ones that come with these were made to go inside a actual server where noise is less of a issue.
