is this the exact same
briin79
Integrated Intel Extreme Graphics
15-pin VGA output on planar
Uses Intel Dynamic Video Memory Technology (DVMT)
32-bit Z-buffer depth
300MHz DAC
For models without a separate video card, memory supports both system and video. System memory used by video may be up to 32MB if the system has 128MB installed, and up to 64MB if the system has 256MB or more system memory installed, depending on video mode.
640 x 480, 16M colors (60, 72, 75, 85, 100, 120 Hz)
800 x 600, 16M colors (60, 72, 75, 85, 100, 120 Hz)
1024 x 768, 16M colors (60, 70, 75, 85, 100, 120 Hz)
1152 x 864, 16M colors (60, 75, 85, 100 Hz)
1280 x 1024, 16M colors (60, 75, 85, 100Hz)
1600 x 1200, 16M colors (60 Hz)
1920 x 1440, 64K colors (60, 75 Hz)
2048 x 1536, 64K colors (60 Hz)
nVidia GeForce4 MX440 AGP 8x
64MB DDR SDRAM
350MHz DAC
15-pin VGA output
640 x 480, 16M colors (60, 70, 75, 85, 100, 120 Hz)
800 x 600, 16M colors (60, 70, 72, 75, 85, 100, 120 Hz)
1024 x 768, 16M colors (60, 70, 72, 75, 85, 100, 120 Hz)
1152 x 864, 16M colors (60, 70, 72, 75, 85, 100, 120 Hz)
1280 x 1024, 16M colors (60, 70, 72, 75, 85, 100, 120 Hz)
1600 x 1200, 16M colors (60,70, 72, 75, 85, 100 Hz)
1920 x 1440, 16M colors (60 Hz) 2048 x 1536, 64K colors (60 Hz)
are these the same thing? would it be better to buy this ge force mx440 replacing my intele extreme? anyone know of cheap pci cideo cards . im playin bf1942 and its hella slow. thankx for your help :D
They are not the same thing, and even a lowly MX440 will beat the pants off of integrated shared memory graphics.
"Uses Intel Dynamic Video Memory Technology (DVMT") means that it uses some of your memory to do its stuff.
So instead of having 512MB of DDR you end up with 448MB.
Real graphics cards have their own memory and work a lot better than any on-board crap.
Not to mention that shared memory is far slower in general than dedicated memory on the graphics card.
