Mike2007x86
- Apr 27, 2007
57c on idle with a Q6600 @3.2Ghz
Its very stable, but it requires a restart every now and then and speedfan says the vcore is all the way up to 1.42v so I am concerned about temperatures. I'm using a watercooling setup with a PA 120.3 radiator with their own yate loon fans in push pull configuration for the rad connected to a laing d5 pump and a fuzion cpu water block and 6 other fans inside my case for airflow.
Is this temperature normal for a E-VGA 680i SLI A1 overclocked at idle without any system resources being used?
Only my CPU is watercooled, everythingelse is bone stock.
