Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
You have C1E and/or E1ST enabled in your BIOS which is Intel's version of "Cool n' Quiet". Your CPU will throttle down when it's not being used in order to save power and generate less heat/noise.
If you're overclocking or are going to be, disable E1ST and C1E in the BIOS.
