is this ram ok for my system
OCZ EL platinum rev.2 is good. G.Skill DDR 550 or 600 is good. basically anything with the samsung TCCD chips. I love my OCZ. no problems yet.
yeah i have been reading this but the main problem here is im trying to order everything from newegg and i cant tell what is TCCD and whatnot
is this what you are talking about? http://www.newegg.com/app/ViewProductDesc.asp?description=20-146-890&depa=0
this is what i had at first but someone said it may not work at all with my motherboard ? http://www.newegg.com/app/viewProductDesc.asp?description=20-146-845&catalog=23&manufactory=BROWSE
Depends on your situation..
OCZ Platinum Revision 2 or Crucial Ballistix will provide the best timings at DDR500 and under, G Skill PC4400CLE or Corsair XMS 4400XL will hit the highest clock speed, timings notwithstanding.
I personally recommend the Crucial. It's as fast or faster as either the G Skill or the Corsair up until about DDR550 which is doubt you will be running anyway, it's slightly cheaper, and it looks better with the gold heatspreaders.
The OCZ is very good RAM but the catch is that it likes a lot of voltage... i.e. 3.0v or greater.
amd_gamer,
Yep that is the ones. They have TCCD chips. That is what I have. The G.Skilll PC4400 (DDR550) is also good and utilizes the samsung TCCD chips. I believe both have similar results. I cant recall all the memory that hass TCCD chips but it is more than just those two.
stnick80 said:
amd_gamer,
cool how is that case of yours how many HD's can it hold? im going to get that or the full tower version im not sure yet
I run my OCZ just fine at 2.85v. In fact my system will boot at 2.60v no problem. OCZ says 2.75v for the EL platinum rev.2
Speed is better than LL though. The latency settings don't seem to matter much at least on my platform. I had to relax my LL OCZ anyway. Your probably going to end up running something like 2.5-3-3-7 anyway. If you want to run your system 1:1 I recommend getting the G.Skill or something similar because you possibly wont have to utilize a divider. The OCZ is supposed to be good up 270-280MHz or so I hear but I only run my at 230 something because I had to use a 166 5:6 divider even with OCZ, at 290MHzx9. Remember DDR 550 is 275MHz so supposedly anything above 275MHz your going to need a divider. You will not lose much performance if any at all from using a divider.
ok GREAT my final system specs
AMD Athlon 64 3500+
MSI "K8N Neo4 Platinum SLI"
OCZ EL Platinum Revision 2 Dual Channel Kit 184-Pin 1GB(512MBx2) DDR PC-3200
eVGA nVIDIA GeForce 6800 GT Video Card, 256MB GDDR3 ( PCI EXPRESS)
Creative Labs Sound Blaster Audigy2 ZS GAMER Limited Edition PCI Sound Card
Lite-On 16X DVD Dual Drive, Model SOHW-1633S Beige, Retail
Thermaltake Venus 12 CPU Cooler For AMD Opteron and Athlon 64
Western Digital Raptor 74GB 10,000RPM SATA Hard Drive
Maxtor DiamondMax 10 300GB 7200RPM 16M P-ATA/133 Hard Drive
ENERMAX Noisetaker 600W Power Supply, ATX 12V V2.0 compatible, Model "EG701AX-VE SFMA 2.0 SLI"
ANYONE SEE ANY PROBLEMS WITH IT? going to order tomorrow
Hmm.... 4 in the removable Harddrive thingie. I love this case. thumbscrews all around. sliding motherboard tray. dual front fans, with dust filter. even the hard drive container has thumbscrews. I think it will hold about 7-8 hard drives total. I only used the front mount 3 1/2s for my floppy which doesnt work, lol. I think it has 3 or 4 i cant recall so that is why I said 7-8.
Yep 1 problem. do yourself a favor and save some cash. Buy a 3000+. they all seem to have the same ceiling anyway. mine get about the same clock as 3500+ and get the same benchmarks. Remember the only difference in the 3000, 3200, and 3500 is the max multiplier. 3000=9x, 3200=10x, and 3500=11x. They are all basically the same cpu with only slight change in the multiplier. It allows AMD to sell to all levels of consumers, especially those who dont intend to overclock.
oh yeah and one more thing, since you seem to have the cash, lol. why not utilize your SLI! get dual 6800s or 6800GTs and overclock the crap out of em.
hmm im getting the winchester core, other than that i think i got badass gaming system and can do some nice overclocking :cool: :D
i may do that, but im going to get a nice LCD screen first
just trying to make sure everything is ok with this config i have not built a system in like 2 years back during the glorious days of the Nforce2 and the XP2500+ :p
and yeah man it will be one hell of a gaming rig. but it makes no since to buy expensive samsung TCCD ram and not buy a cheap CPU that u can overclock to the same levels as a 3500+ anyway
oh one more problem... you gonna build a case out Legos, cause i didnt see one in your list?
oh yeah i almost forget an overclocked 3000+, just for exampe say at 300x9 2700MHz will actually be faster than a 3500 245X11 2695MHz because of a higher FSB. That said there is no reason why you could not change the 3500+ to 300x9 and have the same performance. There is no guarantee though, that you will see 2700MHz with either CPU, i just used it as an example.
or....
..you could buy 1Gb of Mushkin Value RAM for $135 that runs at 2.5-3-3 @ 400Mhz and spend that extra $150 on the processor and end up with a 3800+. Then you could run everything with stock cooling and voltage and WARRANTY, and everything would be quiet and stable and you would get the most dramatic performance bump just from the increased clock speed.
Just my $.02
BTW, I really think a 600w Enermax is a overkill for that particular system. Save your $$$.
Bah and what fun is that. the 3800+ is the biggest waste of money. clocking in at only at 2.4GHz. Even some of the worst winchester overclockers can get 2.4. and here is the skinny, an OC 3000+ at 2.4GHz will actually run faster than a 3800+. You can line AMDs pockets if you want to. Ill take a 3000+ over all of em. Screw a warranty.
How is it a waste of money?
You could run a retail 3800+ with a $40 Vantec 350w power supply, the retail HSF, $130 ram, and a case with minimal cooling.
What do most people do to keep an overclocked Winchester stable? They spend $120 on an OCZ Powerstream, or $250 on a PCP&C 510, and $300 on TCCD ram, and $50 on a good HSF combo, or $200 on watercooling, and a $100+ case with at least 4 fans. You realize you could buy an FX-55 and stuff it in a $60 SLK3700-BQE and be done with it for less total money?
..and in the end which machine is going to be the fastest, quietest, and most stable? The FX-55.
I'm not saying overclocking isn't fun (I do it myself obviously) and I realize this is a board for enthusiasts of just that, but I'm just presenting the logic here. Different strokes for different folks.
thanks for all the input guys, you can help me overclock it next week when its ready to go :D
i just orderd everything from newegg
Lian-Li Aluminum Black case PC-65B
AMD Athlon 64 3500+
i cant wait until the parts are here im sure its going to be a badass gaming rig :D
