Is this PSU Worth It?
-=WooDWorKeR420=-
I just wanted to know if THIS power supply is worth the investment.
I am looking for a PSU that wont need replacing for at least 2 yrs and will accomodate a dual core CPU and crossfire set-up with lots of head room on power. Noise isnt a driving factor in my PSU selection however the quieter the better, cooling however is a bonus.
I just wanted to know what others think about this beauty. And if there is something else that I should be considering!
Thanks
~WooD
PC&C is the best there is. Nothing is totally future proof though and 2 years is a long time. I would go for it if I was you.
Expensive...but worth it.
I think the collective jury is still out on this particular unit from PC Power & Cooling. It's so new that no reputable site has had one on the review bench.
With that being said it's PC Power & Cooling - they have a long history of churning out the topmost quality PC power supplies ever to exist. I would say it's a safe bet that this unit will serve you quite well if you can afford it.
The price actually is amazing considering it's a PC Power & Cooling unit.
That seasonic made PC Power and Cooling ought to cover your requirements OP.
