Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
-What speed is your CPU running at? Stock or overclocked, and if it's overclocked, by how much?
-Do you have your fahcore_a1.exe processes locked to specific cores, or are they just running unchecked?
If your processes aren't locked, you might be able to increase your performance by locking two fahcore_a1.exe processes to each core.
By locked, I mean having a particular process set to run only on a single particular core. Since you didn't understand what I said, I assume that means that they aren't locked. If you were to lock them, you might get better performance. Try going into Task Manager, and setting pairs of the fahcore_a1.exe processes to each of your cores. To do this, follow these steps:
-Click the name header to sort processes by name (so they don't move around).
-Right-click on the first one, select Set Affinity, and uncheck everything except for the CPU 0 box.
-Go to the next process and do the same thing.
-Select the next two and repeat, except this time leave CPU 1 unchecked instead.
-Do the same thing with the next two pairs, except using CPU 2 and CPU3 respectively.
Once you have done that, let it run for a bit and see if Fahmon reports better numbers. Be aware that as soon as you finish a work unit, the processes will close and a new set will start out without the affinity settings, so you have to make sure to check back before either of your currently-running clients finishes a unit.
I checked the affinity and there are already locked. since taking that pic the ppd as risen a little to 1184 on smp1 & 1400 on smp2, for a total ppd of 2325 - 2400.
