Is this possible...
jrdbrn
I want to get a LanBox case...
My current setup is a E6700, 8800GTX, 700Watt Tt PSU, and two SATA harddrives with a full atx case and atx mobo.
Would it be possible to get the lanbox case, abit fatility mobo, and fit everything in it?
I don't want to order everything and it not fit.
You'll have problems to an extent. The hard drive cage needs to be removed to fit a GTX in it.
So you can either reposition the cage (Which I've heard works) or get a adapter to make one of the hard drives bigger and fit it into one of the optical drive bays and put the other in the bay on the side for hard drive / floppy drive.
It can be done, just depends on if you want to do it. Though I have to ask why you would get a fatality board when so many people have had problems with them and there are better boards out?
^ *nods* Get the Giga or the Asus much talked about in this forum. In addition to what was posted, also note that you only have 100mm of clearance for a CPU cooler, which is no problem, but you may not be able to use the sink you have now. I have a lanbox lite, e6850, GTX, and giga on the way right now. :cool:
And why not remove the hard drive cage altogether (its in front of the front 92, isnt' it?) and stick it where the floppy drive goes?
If Tt says a RaptorX can go there, why not just put a regular drive there in any case?
I'd also keep the 7" bays clear as possible, to make room for cable management in the event that you're not using a modular PSU.
(That's what I plan on doing anyways. Yes, my signature is a lie. Why didn't Tt bother themselves to make an aluminium black version? Why? Why the hell do I have to buy a silver one so I don't have to carry a 15lb cse around?)
