chinkecheese
- Oct 23, 2007
I want the most silent computer possible. so I did some research on high quality cases (lian li specifically) and found this case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112148
If you look at this picture
http://www.newegg.com/Product/ShowI...scription=LIAN LI PC-B25B Black Computer Case
Is it possible to put a radiator in place of those 2 fans? Like if I remove the harddrive cage?
I understand that It won't have the best capability as far as watercooling goes especially with the airflow coming in, but what can I expect?
I'm going primarily for silence at the moment.. but also performance..
I also would like to know your personal opinion. I hear that Pa120.2 are one of the best, but I also here black ice can outperform thermochill in many scenarios..
I'm trying to go for the best performance vs cost vs sound, any suggestions?
