current:
isp --> linksys W56GL or whatever running dd-wrt --> wireless --> my pc.
the thing doesnt handle lots of concurrent TCP (torrent) connections, so I was looking at either upgrading my home router, or implementing a cisco 1721 that i have now.
the cisco 1721 only has one (1) 10/100mbit interface, but it is dot1q capable.
i haven't thought this through too much, just throwing it out there..would it be possible...
cable modem --> linksys switch (public VLAN)
linksys switch (dot1q trunked) --> cisco 1721 F0 (dot1q trunked) functioning as a router on a stick
and have the public IP on the public VLAN on the cisco 1721, and then also do NAT/routing on a private VLAN...and have the dot1q link going back to the linksys switch (have the linksys function as a switch/wireless bridge only)?
looks like the linksys dd-wrt will have to support 802.1q trunking (to trunk to the cisco 1721), but is this possible?
the 1721 would be functioning as a 'router-on-a-stick', and i would put the connection from the modem on a seperate VLAN from the other ports/wireless interface - and have the connection from the cisco 1721 router be dot1q trunked with both VLANs to handle routing/nat.
