is this ok?
chris.c
im pieceing together a water cooling system and i want to know if this setup would work well, or work at all.
red = dual 80mm radiator (120 wont fit)
black = 80mm fans
yellow = dangerden RBX block
blue = maze4 gpu block
green = DD12V-D4 pump
any suggestions? also, what i/d o/d tubing should i use?
The block that is less restrictive will get all the flow. They will not cool equally.
Use 1/2 ID tubing.
thanks guys.
i always see people with cpu blocks flowing strait into gpu blocks and i didn't think that was efficient.
but i guess there is no other choice.
