D
Deleted member 210069
Guest
Background Info:
Ambient: ~25C
Cooler: Hyper 212 Evo
TIM: AS5
CPU: 2600k
HT: Yes
Motherboard: GB Z77 UD3
LLC: Auto (whatever "auto" llc means...)
First Test:
Initially I ran 4.8GHz through the Sensor test on Real Temp for calibration. This uses Small FFTs in P95. My Vcore was set to 1.4V. Under load it was around 1.37V. My idle temps were around 38C. My load temps were peaking around 89C!
Second Test:
I lowered the OC to 4.5 GHz and set the Vcore to 1.325V (1.29-1.3 under load). I ran P95 blend testing for roughly 45 minutes. My average core temp was around 75C. Spikes were peaking at 80C. I idle from 38-40C.
Notes:
I have reseated my heatsink at least 5 times. I ran a q6600 at 3.2 Ghz for nearly 3.5 years at 1.4 volts. It idled around 40C. Under load though it was only 65C.
The $200 MC 2600k deal was too good to pass up, and after seeing IB results I am happy with my purchase as I only game and do some minor VM work. I have my first kid on the way, so I could see my computer taking a lower priority within a year. I am hoping for this build to last me 4 years.
Should I try reseating and use the credit card method? I have tried both a line and dot. I am torquing the screws decently on the HSF. I rotate it slightly to spread the AS5 around.
Ambient: ~25C
TIM: AS5
CPU: 2600k
HT: Yes
First Test:
Second Test:
Notes:
