BigRigDriver
- Nov 25, 2005
Hey kidz,
I've got 2 GTX 460s in SLI http://www.newegg.com/Product/Produ...e=gigabyte_gtx_460_1gb-_-14-125-345-_-Product There's a temp difference from the first card to the second of about 10 degrees. I have switched their positions but stil the first card runs hotter than the second. Either card on Solo is at normal temps, so I'm guessing that becuase the first card is sort of in a tight place, makes it run hottter than the other. I have placed an extra fan on the side but the temp only go down by about two or three degrees.
Is this normal? Do you have similar issues with your SLI config?
My setup: http://valid.canardpc.com/show_oc.php?id=1586895
Thanks.
Thanks.
