is this normal
g5604
Hi,
So i have just brought a hazro HZ24Wi and it did not come with a driver and just appears as a plug n play device. Is that normal? also has anyone else got this model? how did you calibrate it?
thanks,
G
It is a standard sRGB display device. It shouldn't need a driver. If you want to calibrate you buy a calibration device. But it should look quite reasonable out of the box. Lower the brightness to a comfortable level and you are probably good to go.
