Is this normal turbo behavior (i7 860)?
techpriest
Can't find an answer to this... Got my board from an rma, previous one was warped (p7p55d-e pro)
At stock /w HT on when I stress all cores the multiplier always raises to x22. Shouldn't it raise only to x21 because it's using all cores at 100%?
Is my ripjaws 1600 running with xmp profile causing something weird? Highest heat is 65cº with a noctua d14
Programs used:
Intel Burn test (tested with auto, 8 threads, 4 threads)
Prime95 (8 threads)
cpu z
realtemp's i7 turbo monitoring
Give me a few minutes to see. I am typing from an i7 860.
Edit: Yes calculated multiplier of 22 when 8 threads are running 100%.
cool thanks. Btw drescherjm what are your temps/cooler at 100%? I'm using a noctua d14 and I'm getting around 65-68c at stock
30C to 36C idle. Let me test load again.. 55 to 60C compiling my C++ source code on 8 threads. I will test IBT. 60C to 73C with IBT maxburn. Above 65C it appears that the multiplier goes back to 21 more often. Calculated 21.6 at 69C.
drescherjm thanks that seems just like mine. I guess I can take the next step now and oc
