Is this motherboard dead?
evilsofa
Motherboard is an ASUS P4S800D-E Deluxe, an old AGP slot 478 board gifted to the father-in-law and now it appears to be dead.
Symptom was that it started crashing a lot. Memtest86+ 2.01 would give errors usually in the 3rd pass which told me it was definitely a hardware problem, not a software problem. In my experience, 3rd pass failures indicate a motherboard issue, but replacing motherboard means total system rebuild which I wanted to try and avoid.
Got a "CMOS Settings wrong" message during one bootup so I replaced the CMOS battery but did not solve Memtest errors. Replaced questionable quality 350W PSU with Antec Earthwatts 380W (which I would use in a new build anyway) and bought 2GB of new DDR400 RAM for $20 (which could be used in another computer if that was not the problem).
After putting in the new PSU, Memtest86+ started crashing rather than failing (turning off USB Legacy Support in the motherboard BIOS did not stop the crashing). Crash was the same with both new and old RAM - it would always lock up and/or display graphical weirdness during test 5 (Block move, 64 moves), so I feel certain that RAM is not to blame here. Upped the RAM voltage to 2.65v from whatever "Auto" was giving it, and got different behavior - Memtest was able to give errors without crashing. Errors still occurred in test 5.
After some more testing, the motherboard quit booting up reliably, then booting up at all. At this point all I get from the vocal POST is that it has failed due to CPU overclocking settings, which is weird because I never overclocked the CPU. Resetting the CMOS using the jumper does not solve the problem. The CPU, a P4 2.8Ghz, is definitely not overheating because I have a good Zalman cooler on it keeping it around 47C idle.
At this point I feel fairly certain the problem is the motherboard. To my surprise, I actually found a motherboard that could replace it, without replacing any other part - the Compaq 283983-001 for $43. But I'd kind of rather just give up on the old AGP crap and get a new case, motherboard, CPU, RAM and video card for a total of $300, because I'm afraid I'll find out the problem was really the CPU or some other dang thing.
Did you inspect the mainboard for visual damage? Especially damaged capacitors can give weird, unstable behaviour.
No visible damage to the motherboard that I can see. All the capacitors look normal, not bulging or cracked.
Well, at this point it could also be the CPU. I'll agree though that it's likely the mainboard.
I concluded that I don't want to find out the hard way whether it's the CPU or the motherboard, so I ordered the new parts I listed above, as well as a SATA hard drive and DVD burner. It will be a very nice and affordable 1280x1024 gaming system for my father-in-law. He was very happy about the cost being under $400 - he was expecting to have to shell out $800.
