Is this mobo dead?
watdahel
I have an Asus A8N-E that will not post, no beeps, and no video. A green led on the mobo is lit up and the cpu and chipset fans are running. The harddrive does spin up. I've tried a different power supply, cpu, ram, video card with no success.
This might sound obvious but you didn't mention it - CMOS reset and left the battery out for a while if that doesn't work?
Also, tried it outside of a case to rule out shorts?
+1
- in addition - what changed (if anything) - - was it working before and then you did ___?
I removed the board from the case. I was able to get the mobo to beep again when I reconnected the case speaker. Initially, based on the beeps it told me it was a memory problem, so I swapped in rams I know is working, but got the same result. When I filled all slots with ram the beep changed to a video problem. I switched the video card and still no luck. No video throughout the tests. I don't want to put any more time on this board. I'll keep it for parts and sell the rest.
hahaha...good luck with your mobo. I had one that was smilar but I think it was the PSU that took it out.
That's what I'm thinking happened to mine. I checked the power supply and noticed one capacitor popped, although it is still running and the voltages appear within spec unloaded.
I don't see anywhere where the OP tried just one stick of ram outside the case with no HDD. I'm envious. I wish I had the money to just replace things instead of making what I have work. :)
I found some time today and decided to try to reflow the solder underneath the chipset using a hair dryer and heat gun. I am ecstatic to report that it fixed my problem. I am so smart. Time will tell how long this will hold up. I wasn't very precise with my heating profile.
