Is this fixable?
JustLong
So a coworker was having problems with his Abit IC7 Max III and finally gave up on it. He asked if I wanted to have the POS. I figured it was a user problem and who could pass on a free mobo. When I went to install the board I felt something on the under side and flipped it over to see this:
can't really see very well but it looks like the top layer of silicon is ripped off the board, at least the wire that was embedded was ripped off.. in that case there's nothing you can do IMO. I've enver seen a fix for something this severe... RMA?
~Adam
That seems a little odd to me, I wonder how that could have happened? Maybe it would be considered a manufacturing defect of some sort. Maybe email abit and send a picture they might replace it. Never hurts to ask, you'd have to be insane to try and pry that up or whatever.
"I got an idea, lets gouge my expensive mobo with an exato knife and see what makes it tick.." lol
~Adam
Yeah the wire was torn out of the PCB. I think it still worked because it was still making a weak connection by both ends making contact on the case. I figure one of those solder pens might fix it, but I wouldn't trust a board to work very well in that state. Also I think most RMA policies don't allow for physical damage.
I didn't expect it to be fixable, but thought it was worth sharing.
i would think soldering the connection would help(may not fix it)
but how in the hell did that thing get torn off :confused:
well that trace was lifted.. guess you can try soldering a wire between the two points the trace leads to and hope it works.
It's very possible to jumper that trace. Just take a thin piece of wire and solder it on both ends. I ended up doing something similar when I blew 5 traces in an old Pioneer receiver I had.... That's what I get for bypassing a fuse....
I might try that, I never thought it could be a manufacturing defect.
Had a stereo quite a while ago with acrack board in it. Was able to do some point to point wiring to bypass the cracked board and got a lil bit more use out of it until one of the channels started to go out. Got tired of ripping it apart so just trashed it.
If you do jumper that, try to find the closest solder point to that damage to jumper an insulated wire to the solder points instead of having to scrape the coating and soldering on the trace. This way will give you a stronger connection that will last longer. No sense in putting more stress on an already bad trace.
I doubt that would be covered under warranty as the only logical way that could happen is for something to scratch across the trace and lift/tear it. Doesn't hurt to try though.
id try to rma it first, and if abit wont take it try fixing it by soldering a wire in its place.
Traces can be fixed, Im pretty sure thats one of my friends dads jobs, to fix traces on components, I say go for soldering it
That's what I would do. That can be fixed/saved with a steady hand...later:)
