Is this enough radiator for my setup?
2dFx
Planning my radiator requirements for my new semi-uber build. I'm planning on running 2 pumps.
Loop 1 = pump --> r9 fury --> 240mm rad --> r9 fury #2 --> 240mm rad #2
Loop 2 = pump --> mobo vrm --> chipset --> 5930k --> 360mm rad
Is a triple rad really enough to support that kind of heat load for plans of pushing the 5930k north of 4.5GHz?
360mm it's overkill completely for a 5930K at any speed... In my opinion you will be perfectly fine with 2x 240mm radiator for the whole setup or if you want a 360mm + 240mm
