Is this enough for a router?
zidion
I have this cheap old pc and wasthinking of trying and making a router (its just sitting in my garage, might as well do something with it).
spec:
pentium 66mhz
24mb ram
540mb ram (I have another hd i might be able to put in if it will work, 10gigs)
is taht enough to run like smoothwall or something?
Definately. It may be a little slow installing and opening up the configuration web page, but it should pass traffic just fine.
it would be much better than my first router, a 486-33 with 8 meg of ram, I had a time finding a linux distro that would run properly, but it was really slow so I took it down.
My first router:
Slackware Linux 4.x
P-233MMX
64MB Ram
6GB Hard drive
Two 10/100 3com NICs.
That system was slow but did the job nicely.
Here is a 'show version' from my firewall. A low-end Pentium should work fine, but 66mhz will be pushing it a tad for anything but passing packets.
PIX# sh ver
Cisco PIX Firewall Version 6.2(3)
Cisco PIX Device Manager Version 1.1(2)
Compiled on Thu 17-Jul-03 08:16 by morlee
PIX up 200 days 9 hours
Hardware: PIX-515, 64 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
I think people are underestimating low end machines these days. The first router I had running was a 486DX2-66 with 16 MB ram running Win98, at it worked fine. The ISP I used to work for started out with a single Pentium 66, running NT Server functioning as a domain controller, web server, dns server, and RAS authenticator for 300 users.
People seem to think that anything less and a 200 Mhz machine these days is worthless, and perhaps it is for today's software. But running the software that they were designed for, these machines are quite adequate.
Using a machine for a router doesn't take that much RAM, once you get past the OS overhead. Passing packets doesn't take that much memory, and is usually handled by the DMA of the processor and the network card (aside from firewall filtering). The main pain is the slow hard drive I/O.
It should work fine though I'd still probably throw a stick of RAM in there if you had it.
so how wud u go about do this then wat software etc, i hav an old Duron 700 sitting in the coner of my room, mite as well put it to use
Throw any number of diskless Linux solutions at it or load a linux distro on the box.
Internet----linux machine with two ethernet cards----singe computer or switch for multiple computers.
nick_sabatino, Fint didn't install PIX on a pc, he was just showing the specs of his cisco device as compared to a pc.
joey222 said:
would suse 9.2 do the job?
Any distro will work but when choosing what to install keep it to a minimum. You dont need X windows, Gtk, QT, Gnome. Kde, Sound Driveres, etc etc. For passing packets back and forth, you dont want to bog down your already slow machine with GUI stuff.
suse is kinda a big package for something that needs practically no processing power, unless you booted to a prompt or something it would hog the memory...
say, if i wanted to create a switch out of a computer, would it be possible to have 6 network cards all supported by the OS? the mobo is a KT7A-RAID if that helps.
Natively no. Might be some software out there. Why would you would be my question. The better choice would to just get a multiport NIC rather than multiple NIC's.
It would work, but take a decent amount of work to learn the config to do such a task. The end result would be one expensive 6-port managed switch.
well at our LAN's we usually have 3-4 24 port switches and we need something to connect it all. in the past we've used things like 8 port switches, but wouldnt it be faster to have a computer do the connecting?
They don't work too well with multiple ethernet cards. You'll need a switch instead of a bunch of NICs in the computer. But the 66MHz will be fine for routing.
Check out clarkconnect, m0n0wall or freesco
my first router was an AMD 386 12mhz with 4 megs of ram, an external dial-up modem and an ISA 8-bit 10mbit ethernet card
beat that
it worked fine until a mouse decided that the motherboard needed some urine.
For packet passing, and minor ACL work that machine should be fine. Although, if you could dig up some more RAM, that would be good.
For a truly lightweight router, go with Coyote Linux.
I've used Smoothwall (nice, but bloated), FreeSCO (trying to be too many things at the same time) and a non-DIY router (underpowered, buggy) before settling on Coyote.
Best thing about Coyote is that you don't need a HDD. Just a FDD and a single floppy is enough.
