Originally posted by texuspete00
It has a decnt one. Reapplying yoru own paste usually improves cooling marginally (or a lot if the mffg monkeys didnt get much sleep that day). You might get limited by something else other than nb cooling anyway. I uaually reapply paste for day one then see what's what. Swiftech has one of the better nb sinks, and another good one is called the northpole I believe.
edit: I forgot your goal is a very aggressive one. One that might even require phase change on your cpu... in other words you do need to get lucky and/or swing the tides of luck in your favor. Ah well, see if luck shines upon you first. If it's that 2.6 in your sig you are going to need over 300fsb to achieve 4.0GHz.
