Is This Cooler A Good Choice
If you're set on Thermaltake, for that price go with the Frio, that's the best cooler they make.
If you want something almost as good for a lot less money, get a CM Hyper 212+
The Frio is a monster but it's a bitch to install and blocks off the first RAM slot on lots of boards.
Thermaltake is not the place to be looking if you are wanting a nice tower cooler for OCing, as someone else said, the Hyper 212 Plus is hard to beat and a great cooler, it's also a good deal cheaper than the one you linked to and will perform much better.
The Hyper 212+ is definitely a nice HSF. For the price, its hard to beat. The Corsair A50/A70's are supposed to be pretty decent too but I'd lean toward the 212+. Also worth taking a look at is the Scythe Mugen 2.
Then again, what are you looking to spend?
Short answer, yes. Long answer, yes, but I would pick something different. If I didn't need the first two RAM slots, I'd go with Thermaltake Frio if you're set on the brand, but as others have said above, the Hyper 212+ is pretty much the best bang for the buck air cooler on the market right now, I also like the performance of the A70. The nice thing about getting something better than what you need right now, is that you'll probably be able to use it in the future as well, for example, when the 6 core processors come down, or maybe even some of the lower end bulldozers when they're released.
EDIT: Check out this thread from [H]otDeals, several people are seeing the A70 at local Best Buy stores for under $30. If they are out of stock, some are able to order it with price matching. http://www.hardforum.com/showthread.php?t=1576710
I fifth the suggestion on the Hyper212+. There was a time when I was considering getting the Hyper but after much research I found the Zalman Performa better when high OC was invovled. Regular price the zalman is double the hyper, but I found the zalman on sale for $30 so it was a no brainer for me.
I have the 955BE at 3.8 with a zalman performa. Temp is 26-30c idle and 47-52c running prime95.
The Hyper 212+ is SERIOUSLY hard to beat for what it costs.
