Is This Build Fine?
AVAFREAK182
I know its not the best, but I bought most the parts used and cheap.
Lian-Li PC-7B
Raidmax Quantum 700W
AW9D-Max
E7200
TRUE 120
2x2GB GSkill PQ
320GB WD SATA
HD3850
22X Samsung DVD-RW
Windows XP 64-bit will be the OS.
All tallied up, I spent $513.97 on the build. Not too shabby.
The AW9D Max uses the i975X chipset, but it may not be able to support the E7200. Check the Abit site to be sure, though.
It doesn't say, because it doesn't have a list of supported CPU's.
It says it supports the E8200 and the E8400.
