DaRuSsIaMaN
- Apr 22, 2007
This is an old PC. I'm using an EVGA geforce 7600GS 256mb (agp) video card.
Right now with little activity I'm seeing temp of 61C for the gpu according to gpu-z. Earlier I ran FurMark for a little bit, and temp maxed out at about 90C or just below.
1.) Is this acceptable? Seems rather high... but will it be okay nonetheless?
Btw, this is what it looks like:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130036
But mine also has extra heat sinks on all the chips surrounding the gpu, which are not present in those pics. (got it from CL)
2.) If these temps are kind of high, what might be the cause? The heatsink looks less sophisticated than some other cards from that same era... is that the explanation??
