Is this about right?
Dioz_ako
Sorry if this is the wrong forum...
Hello all. was wondering if this score on 3dmark 03 was right..
2700 on this system
Raidmax Scorpio-868 ATX Mid-Tower Case w/420W Power Supply
Intel® Pentium-4 Processor 3.0 Ghz CPU [512K Cache, 800MHz FSB, Hyper Threading Ready]
Certified CPU Fan and Heatsink + 2 Extra Case Fans
MSI 865PE Neo2-PFS(Platinum) i865PE Chip 800FSB DDR400 w/LAN, 5.1 Sound, USB 2.0 8x AGP Motherboard
1024 MB Dual Channel [512MB X2] DDR-400 PC3200 Memory Module (not sure on name brand)
[Serial-ATA] Seagate 80 GB 7200 RPM SATA-150 8MB Cache Hard Drive
56x CD-ROM Drive
52x24x52 CD-RW Drive
Ati Radeon 9600 pro - 128 mb
Windows xp home edition - This pc was build by www.ibuypower.com
Keep in mind i ordered it with a preformated hd and bough the winn xp my self. Ive installed all the latest drivers from windows update. and the cd that came with the motherboard for the onboard stuff. I know the video card is not all that great, but was hoping it would perform a bit better? Or is this as good as its gonna get? (i will buy an 9800pro when i have the spare gaming cash )
Nothing is Overclocked, or no hacked drivers. Every thing is official stock stuff. Mainly because I dont know how too ;) Any comments / sudgestions would be good. and thanks for taking the time to read the post -
Miguel
Go to your ati drivers control panel and set all the textures to high performance and also set Anti aliasing and Anistropic filtering to application preference.
You will probably score in the 3700 range.
Thanks for your reply.
When i set it to application preference should i put them on any thing specific? 2x / 4x ect ?
