Jan 21, 2010 #1 M MrCrispy 2[H]4U Joined May 14, 2007 Messages 4,001 Lancool K62 case, with its included fans Core i7 860 with Corsair H50 cooler I'd like to get a modest OC while keeping things quiet. Are there other heatsinks that work better at the same noise level?
Jan 21, 2010 #2 W W.Feather [H]ard DCOTM x4 & [H]DCOTY x1 2FA Joined Nov 10, 2009 Messages 11,817 honestly it all depends on what fans you use on the H50.....if you get low sound, and higher airflow fan it will work out to be quiter
Jan 21, 2010 #3 M MrCrispy 2[H]4U Joined May 14, 2007 Messages 4,001 How's the stock fan it comes with?
Jan 22, 2010 #4 S scaarbelly Supreme [H]ardness Joined Dec 11, 2008 Messages 4,462 The GPU and PSU also can be major sources of noise.
Jan 22, 2010 #5 K King Icewind Supreme [H]ardness Joined Jan 17, 2008 Messages 5,441 Corsairs fan really isn't all that loud when other fans are running as well. Of course that was with the Antec 902's 240mm, a PCI slot fan, and three 120mm fans. Now I wouldn't I can't hear anything since I have 13 fans
