My friend bought a bunch of computer parts from Newegg last week. The parts arrived yesterday, so I went over to his house to build the computer. I put everything together and tried booting it up. It turned on but there was no video output. Swap the video card; no output. I took the computer home and after I got back from class an hour ago, I took everything apart and rebuilt it with only the motherboard & processor, video card that is known to be good, and the RAM.
Everything turned on but no video. Swapped out the first stick of RAM with the other stick, and the same thing happened. I don't think the RAM is the problem unless both sticks were DOA, so it probably is the motherboard or the CPU.
Specs:
Motherboard: Abit NF7-S
RAM: Geil Value Series Golden Dragon 3200 (sticks of 512)
CPU: AMD Athlon XP 2500 with retail Heatsink
If anyone can help, it'd be much appreciated.
EDIT: More stuff added below.
Cleared the CMOS a few times. Same problem.
I tried it a few times with the motherboard, CPU, RAM, and video card in the case. Then I repeated the process with the motherboard in the motherboard box so no metal was touching the motherboard.
I did reseat the CPU. It didn't look burned or smell the part, so I don't think that's the problem.
I'm leaning toward the motherboard because even though the speaker wire is correctly plugged in, there are no beeps.
Specs:
