Is this a mobo problem?
pazhman
I recently installed the G33T-M2. In BIOS my temps read 39-40. On programs it reads totally different.
What do you think is the problem?
Put a load on your processor and see what the Load temps are then worry about what the temps say. Idle temps really dont mean much in that they can always run cool but heat is what is bad for them.
I just want to know why are the temps so different on each program and in BIOS they read 39-40.
Core temp and your motherboard monitoring program (speedfan in this case) use different sensors. Core temp measures internal CPU temp, speedfan measures the temp in the CPU socket of the motherboard.
Believe the speed thats correct :)
When they update their software to support your board properly it should read correctly.
What about my core speed on CPU Z?
That's speedstep kicking in. It lowers the multiplier to x6 instead of the normal x9 and also lowers the voltage. You can turn it off in bios if it bothers you.
Wow, I hope you find out what is causing the discrepencies between Core Temp and SpeedFan. I have scrounged around my closets and came up with a E6420 CPU, some DDR2 RAM (2x 512 PC5300), a SATA HD and a SATA DVD burner, etc and I got a G33T-M2 mobo on Ebay for like $47 bucks with shipping. I loaded WinXP with SP2 and both Core Temp and SpeedFan mirror each other. (I never pay any attention to the mobo cpu temps or the temps at idle, unless of course they are really outrageous)
Oh yeah, I always, by habit, turn EIST and the C1 thing off in BIOS. All my chips are mildly OC'ed and I was taught to do that (shrug) by a folder I respect.
