matrix563
- Sep 1, 2006
i was trying to fix an hp media center pc for my coworker. unfortunately in the windows setup screen, where it says waiting to load windows setup it just locks there, after loading the drivers. i tried removing all the peripheals and using a different dvd drive and it still hard locks.
when it does the lights on the keyboard all flash on then off and then the keyboard is unresponsive as well. is this a mobo issue? my coworker is going to buy another motherboard but i wanted to be sure.
i did a memtest and harddrive format and scan with seagate sea dos tools. both check out fine. i also reset the bios. anyone?
