Is this a Hydis Panel??
GetFunk01
HITACHI CML175SXW2B 17" LCD Monitor w/ Speakers -RETAIL
- Specifications -
Panel Type: Active Matrix TFT
Native Resolution: SXGA 1280 x 1024
Pixel Pitch: 0.264 mm
Brightness: 250 cd/m2
Contrast Ratio: 430:1
Response Time: 20 ms
View Angle: 160°/130° (H/V)
Input Connectors: D-sub, DVI-D
Features: Integrated speakers and headphone jack, Kensington Security Port
Dimensions & Weight: 14.7" x 15.5" x 8.0" (WxHxD) / 11.0 lbs
Manufacturer's Warranty / Phone No.: Standard 3-Year Warranty / 888-338-6490
Dead Pixels Policy: Replacement or Refund for 8 or more DEAD PIXELS ONLY!(Mac use may require adapter, not included)
I believe that is an AU panel. The only Hydis screen I have found is the Hercules 920 Prophetview.
Nope the response time of 20ms tells you it's not the AU panel!! They are all 16ms panels!
