Is this a good temperature??
icehokplyr
Okay, another stupid question here:
I just built a new computer. I have a mid size Lian Li case with 4 acces fans(8cmx25) working. Two in and two out. My cpu temp is 50.0 C. Which is also 122.0 F. The sys temp is 39.0 C. Which is 102.2 F. Is this a good temp or is it running too hot?
I have a Guru Abit Motherboard that monitors the temp. Please help me out here?
Thank you in advance
Thanks for responding.
My CPU is:
Intel Pentium 4/ 3.0E GHz 800MHz FSB, 1MB L2 Cache, Hyper Threading Technology - Retail
Model# BX80546PG3000E
Item # N82E16819116171
Specifications:
Model: Intel Pentium 4 w/ Hyper Threading
Core: Prescott
Operating Frequency: 3.0GHz
FSB: 800MHz
Specifications:
Core: Prescott
FSB: 800MHz
Cache: L1/12K+16K; L2/1MB
Voltage: 1.25V - 1.525V
Process: 0.09Micron
Socket: Socket 478
Multimedia Instruction: MMX, SSE, SSE2, SSE3
Warranty: 3-year MFG
I'm cooling her with:
ZALMAN CNPS7000A-Cu Pure Copper CPU Cooler for AMD XP Socket 462/ 754 and Intel Socket 478
Model# CNPS7000A-Cu
Item # N82E16835118109
Specification:
Compatibility:Intel Pentium 4 (Socket478), AMD Athlon/Duron/Athlon XP (Socket 462), and AMD Athlon 64 (Socket754) .
Dimensions: 109 (L) x 109 (W) x 62 (H) mm
Bearing Type: 2 Ball
Nominal Speed(RPM): 1350~ 2400
Max Air Flow:(CFM): Not Specified
Max Pressure: Not Specified
Heat Sink Material: Pure Copper
Rated Voltage: 12V DC
Noise(dBA): 20~ 25
Special Features: Adjustable fan speed controller(Fan Mate 1)enables control of noise and fan performance.
and my room temp is about 75 Degrees F.
50c is a fine temperature, it isnt wonderfull.. sort of in between
edit: 50c is wonderfull for a prescott
Thank you for the reply.
So, I am okay then?
plz do not copy and paste those newegg descriptions of the product. Most ppl here already know them and it just takes up space and its rather annoying.
These temps are all the time. It sometimes goes up or down a degree but has been pretty much running like this.
max is 70*
50* is okay... it's not great, but it's certainly not bad. What are you using for thermal grease?
Try Motherboard Monitor 5 and see if it registers different temps. MBM5 reigisters my temps 5 degrees lower than my boards utility (MSI's CoreCenter has been known for it's innacurate temp readings...maybe yours is reading high as well)
Hey bro, please dont post anything if its not going to be relevent to the thread. Its not really helping him out any.
Anyway, yea 50 is pretty moderate for the "E". Unfortunately it runs hotter then the others. You'll be OK, just be careful if youre going to OC it. You can always try water cooling too. Good luck.
potroast said:
max is 70*
its a 3.0E theres no way its going to be less then hot-ish even with wc you get hotter then usual temps
Thank you. I'll try it out now and reply.
