Is this a good power suppy
For a '500w' psu it sure is underpowered when it comes to the 12v rail.
edit - If you are intent on not spending a great deal on your psu, I had a look around that site and for $5 more than your initial choice, I think you would be far better off with this psu: http://svc.com/rs-430-pcar.html
Unless the reason for your choice was purely aesthetic.
Congratulations! You have picked possibly 2 of the worst power supplies on the market!
My 300w fsp will kick the shit out of the Powmax. Read said stickies here, and you'll see. A powmax has No guts at all. Tiny ass capacitors, heatsinks which are just a plate with holes drilled into it..
Avoid them at all cost.
What do you need to power?
Total trash!
System specs please.
hellomynameis said:
Please look my sig below and tell me if this will work good for me
http://svc.com/psas-ta.html
or
http://www.svc.com/w0070.html
Right now i have a Antec Smartpower 2.0 350watt
Your current PSU is better than either of the two that you're considering, even though it's still less than ideal for your rig. (Your motherboard has no 4-pin ATX12V connector; thus, it cannot take any advantage at all whatsoever of the second +12V rail on that SP350 unit.) The Powmax is one of the worst-quality PSU's on the market, specs notwithstanding. The Thermaltake W0070 is an older-design unit with a single weak +12V rail that may barely suffice for your rig.
These days, it's very difficult to find a new PSU with a single +12V rail unless you go really cheap (the Powmax comes to mind) or really expensive (the PCP&C 510W comes to mind). Pretty much everything in between those two extremes have dual +12V rails.
now this is from the manual and the website. and yes i do have the 4 pin
Standard 20-Pin-ATX-Power Supply Connector + 4-Pin (ATX12V)
actually, quite a few newer psus are moving back to single rails. my guess would be because some video cards (especially is its SLI or Crossfire) pull more amps than dual, triple, etc rails are carrying.
