Is this a good C2D build?
deaNhaycH
I just got the go ahead for a £600 budget upgrade, so this is what I had in mind:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-150-AS
http://www.overclockers.co.uk/showproduct.php?prodid=CP-135-IN
http://www.overclockers.co.uk/showproduct.php?prodid=MY-057-GL
http://www.overclockers.co.uk/showproduct.php?prodid=GX-065-HT
http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-SB
I will be overclocking.
What do you guys think, is that worth it? How will it be for overclocking?
Anything I should change?
Thank you <3
look good
Though I'd get the P5B-E (or gigabyte DS3), not just the P5B.
The plain P5B doesnt have as many voltage adjustments and has not overclocked as well b/c of it.
