Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Have an asus p4c800 e deluxe with a 2.8c equipped with a 92mm tornado fan. I was going to do a test boot with just the motherboard, cpu, memory, and video card. Will this work and give me post if any errors in components are present?
In short, yes, you can do that. It's a good idea to install just a few parts at a time and boot the system to see if it works. That way, it's easier to know what part is bad (if any are).
As long as memory is present and a monitor and PSU attached, Yes it should at least boot to a "insert bootable disk" message or the "Floppy disks fail" message or get you started on debugging parts.
