Heres the problem - Im currently overclocked to 3.4GHZ on my Conroe E6700, and under idle CoreTemp reports my CPU With a Zalman 9700 @ 51 degrees Celcius. Which may not be bad, however, upon running Orthos for as little as 1 minute, it shoots up to 71 degrees Celcius, would this be too much of an overclock, or is my cooler messed up/ in the wrong position? With the CPU @ Defaults, it remains at a perfectly fine 48 Degrees Celcius under load.
Current Specs:
Conroe E6700 @ 3.4ghz Overclock
EVGA 680i Motherboard
2x1GB PC8500C5D
Current Specs:
2x1GB PC8500C5D
