Guess you never got into the Alt+Tab habit, the King of all Windows keyboard shortcuts. Flip3D is right there, almost the same hand motion, but I guess those people that never got into Alt+Tab will get into it now, using the mouse and the Taskbar has become to engrained.
There's probably a way to do it, but it's all dependent on your mouse software if you use that stuff, so check and see if you can enable that functionality or check the manufacturer's site for a support forum you can ask that same question or request that feature be added.
Alt + Tab does not open up Flip3D anyways....it only opens up a more classic Alt + Tab menu.
