- May 11, 2016
Without removing the heatsinks or taking them out of the system, and without installing some kernel-level software that I'll likely never use aside from for this task?
"dram calculator for ryzen" might and i know there is another app that can but i cant remember the name...
thats the one, never used it though...I'll check out DRAM calculator. Thaiphoon Burner apparently can, but it keeps saying this when I run it, even when I disable Windows Defender and manually run the program as administrator (though my account is also the administrator account).
And that prevents Thaiphoon Burner from being able to detect and read the memory information.
I think the memory tab in cpuz tells you the chipsWithout removing the heatsinks or taking them out of the system, and without installing some kernel-level software that I'll likely never use aside from for this task?
Read the readme that came with thaiphoon burner it tells you what you need to do.I'll check out DRAM calculator. Thaiphoon Burner apparently can, but it keeps saying this when I run it, even when I disable Windows Defender and manually run the program as administrator (though my account is also the administrator account).
