Is there a visual difference between vga and dvi out puts?
Celsius
The reason I'm asking is because in a few days I will get lcd 19 inch lcd monitors with both dvi and vea imputs. So I wanted to know, have any of you seen a difference? I understand the ghosting aspect of the games but they are high-end viewsonics so I don't expect to experience that too much.
I'm moving from one 17inch viewsonic and one 21inch monitor made by sony (btw, both for sale if you live in Phoenix).
So what am I in for?
Thank you, Jason
DVI is noticeably better. Maybe not jaw droppingly noticeable but i'd dare say that everyone would agree that DVI def looks nicer...
The differences vary depending on what moniter/TV you're using.
from what little is stored in my sriveled up neolithic brain, i think dvi is better(hd, as aposed to non hd vga) kinda like normal rca vs. component
Is there an advantage of connecting a non-DVI monitor to a DVI graphics card via an adapter?
I have two 20.1" LCDs and I can say that the one using DVI is noticeably sharper. There is no benefit to using a DVI adapter...I've never noticed a difference using multiple CRTs between the DVI converted and the standard D-SUB output...but I would imagine that the conversion process makes the signal slightly worse...
In general you probably won't notice the difference unless you have an LCD, and then, it's a definitely difference, no blurriness whatsoever...
i just switched from an analog 17" lcd to a 20.1" lcd, dvi is definatly sharper.
DVI is definitely better... i have my LCD connected to two computers, one analogue, one DVI (so i can switch computer display by just switching input), and i can tell the difference between the two.
Thank you very much. Man if we talked about stocks and money making we would be dangerous.
Sincerely, Jason
