Is There A Program To Read Your Cpu Temperature?
alghazanth said:
Try your BIOS. ;)
try your finger - or your tongue - or you know what. you might have to pull the heatsink off for that one. just shut down your computer, pull the heatsink off, smear some thermal grease on an appendage of your choice and press it firmly against the CPU's core, then hit the power button. the result will amaze you, your neighbors, and the paramedics, i'm sure. :)
What was the qeustion again? The shouting left an annoying ring in my ear.
Motherboard Monitor 5 is the simplest program for monitoring CPU temps. It also gets system temps and fan speeds etc...
