is there a pin-mod for the A64?
Naldo
Can you adjust the voltage to the CPU using wire in the socket like you could with the XP's?
I know, but if your bios didnt let you change it you could do it by putting wire in certain pins on the socket, is this possible to do with the Athlon 64 CPU's?
I don't think there is.... If it becomes published I know ocinside will have a workshop thingy for it.
Rad777
