Is there a mounting mechanism for a 50mm res that...?
theDeviL
Is there a mounting mechanism for a 50mm res that allows me to mount it along the side of a rad with 120mm screw holes?
1/2" strip of metal, 1/8" thick. drill and countersink two holes to mount it the res. add two Hose clamps in the SAE size ranges of 26 to 28 to clamp the res to the metal strip. bend the bottom of the metal strip 90 degrees under the res if you want to get fancy.
yeah it looks like I'm gna have to McGuyver something together to make this work. thanks for your opinions.
should not be too hard. let us know what you come up with.
edit: added the not where is was missing
cool ill watch for it
