Hitokiri Batohsai
- Apr 22, 2003
My pc has some lights, and there is no switch to this. The lights are connected to the molex connector, two wires protuding more to the lights.
Is there molex switch, controller that can just do the on/off function. So that I can turn on, turn off the lights whenever I want. I don't want to open the casing everytime to cabut, and sambung the damm molex connector.
if this type of connector does not exists, any other solution. I was thinking of going to the hardware shop, buying a normal flip on/off switch, cut one of the stray wires and placing it in between. There, easy light connector. But needs work. And also drilling one more of the floppy bays, to place the switch there.
Its a bit tedious.
Thanks
Its a bit tedious.
Thanks
