Hi everyone,
A little background on the situation:
I frequently need to help people create video files with a final target universally either .wmv or .mov (depending on whether the person needs to be able to work on/view the video on a PC or Apple). Due to their common nature and the high probability that anyone with a computer will be able to view them once they are in one of these formats, .mov and .wmv are ideal for our purposes.
These files come to me in many different formats and I end up usually relying on a self designed toolbox of various programs to get it from whatever format it comes to me in, to a usable format. However, sometimes this ends up with me having to run the clip through multiple different encodings with different programs in order to end up with a final result that I can hand back in appropriate format.
An example:
I had a clip come in yesterday from a random camcorder, that had been edited with Adobe Premier and turned into some form of mpg.
In order to turn this clip into a .wmv I ended up having to encode it 3 different times:
First - Handbrake to change it from mpg to m4v.
Next MPEG Streamclip (which refused to recognize the original mpg) to change it from m4v to avi.
Finally, Windows Movie Maker (which rejected both the mpg and the m4v) to turn it into a .wmv.
Re encoding this video 3 different time did result in a bit of quality decline, as well as taking several hours by the time all was said and done (the computer I do this work on is not cutting edge, although it is not bad either.
My question is this: Could I have streamlined this process? Is there a freeware or cheap program that could have gotten me straight from an Adobe Premier mpg to wmv or mov? Is there a well designed universal translator type program, or is my current procedure of just having a toolbox on hand to deal with the million different formats things come to me in as efficient as I could get?
An example:
