Red Squirrel
- Nov 29, 2009
I run my own email server online with postfix and dovecot, but my local mail server at home is what actually stores all my email so I use that server with imap. When I send emails I use my online SMTP server since lot of RBLs block ISP residential IP ranges. The only issue is that because I don't want an open relay, I have it setup so only my home IP can send. Now sometimes my home IP changes, like if my modem is disconnected for a long time. Then I have to go on my server and change that setting.
Is there a better way of handling this? Or should I just look at getting a static IP for home? How do web hosts do it? Do they have a system where when you authenticate through pop3 it puts your IP in the SMTP white list? Is there a way to set that up with dovecot/postfix? If it matters, I'm using pop3 secure, and not just plain pop3.
